How much battery life are you getting with the One Max?
giovanni6
4
Since upgrading to KitKat, I feel like my battery life has decreased. I'm getting about 6-7 hours of on-screen usage. Not bad, but definitely not living up to the hype.
Kelly Burby
Banned
Nov 26, 2013
693
I think you should try installing some battery saver applications, look what the problem with the Android ecosystem is application keeps running on the background even if you close it, the idea behind is Android keep running the application in the background, in order to provide you faster access to the application. Here battery saver apps played an important role by cleaning up those application after a certain interval which in return help you in using that power for your use.
Nanran21
