1. TCBCSM's Avatar
    Hello everyone TCB here.
    I rooted my phone and unlocked it used the all in one tool kit.There is no OS installed on the mobile, I installed a rom in twrp than after it as done, it boot looped than locked up and I accidentally deleted the OS.
    my phone is htc one s (s4)
    I can get into bootloader / fastboot menu I can get into twrp, when I connect usb it says "fastboot usb in red" in the fastboot boot loader menu so that should be connected but its not. Only time it connects is in twrp, my computer will detect "htc mtp device" it shows up fine in device manager, but after about 10 secs the device is no longer be detected and yellow ! will show over "htc mtp device" in device manager. What is weird even more is I can run certain command with adb " adb devices" tells me its connected but it wont sideload or fastboot , it just says "waiting for device". I can restart the usb by "adb usb", it will temporary install and run but 10sec or so later is disconnects and yellow! will show over "htc mtp device" in the device manager. Does anyone have an idea how to fix this? Is my phone a hard brick now?
    Please help me.
    Attached Thumbnails I really need help figuring this out.. USB Problems-device.jpg
    05-16-2014 09:15 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    I am unfamiliar with HTC devices, but I can try to get someone to help you.
    05-16-2014 10:30 PM
  3. wizzrah's Avatar
    Please help me.
    Hello. I'm assuming you have the drivers installed? Also, what commands can you run?
    Wizzrah | AT&T HTC One XL | Tapatalk
    Golfdriver97 likes this.
    05-16-2014 10:35 PM
  4. TCBCSM's Avatar
    that would be great thanks
    05-17-2014 01:31 AM
  5. TCBCSM's Avatar
    Yes I do have drivers. If im in twrp I can run commands from windows with adb, adb device adb usb thats about it. The usb connection only last for about 20 to 30 seconds than I have to unplug and plug back in, its not the cable I tested 3 diff ones and I tested the usb ports.
    05-17-2014 01:33 AM
  6. TCBCSM's Avatar
    Thank you! That would be so great..
    05-17-2014 01:44 AM
  7. TCBCSM's Avatar
    anyone out there please help me !
    05-17-2014 04:18 PM
  8. Golfdriver97's Avatar
    Did you make a backup of your current ROM?
    Sent from my HTC One_M8 using AC Forums mobile app
    05-17-2014 04:44 PM
  9. TCBCSM's Avatar
    Here is the method I tried to install after the All in one tool I used that messed this up. This is the reason I said I needed ADB and Fastboot cause it has to be used.
    HTC One S Android 4.4.2 Update - Android Panel
    I originally followed this guys youtube vid showing me how to use the all in one tool kit, everything was fine till TWRP installed the rom. So I thought I could fix it and it only made it worst.
    05-17-2014 05:24 PM
  10. TCBCSM's Avatar
    I backed up my files from HTC SYNC and used another program called Helium.
    05-17-2014 05:25 PM
  11. TCBCSM's Avatar
    Installing '/sdcard/Liquid-Kitkat-v3.0-NIGHTLY-d2att.zip'...
    Checking for MD5 file...
    Skipping MD5 check: no MD5 file found.
    Warning: No file_contexts
    (_)) ((_) (_)_) /((_)(_)) (_))
    | | (_) / _ \ (_))( |_ _| | \
    | |__ | || (_) || || | | | | |) |
    |____||_| \__\_\ \_,_||___| |___/
    <%%% Liquid-Kitkat %%%>
    <%%% By LiquidSmooth %%%>
    Erasing System...
    error: make_ext4fs: open: No such file or directory
    longjmp botch.
    E:Error in /sdcard/Liquid-Kitkat-v3.0-NIGHTLY-d2att.zip
    (Status 0)
    Error flashing zip '/sdcard/Liquid-Kitkat-v3.0-NIGHTLY-d2att.zip'
    Updating partition details...
    I:Unable to mount '/usb-otg'
    I:Actual block device: '', current file system: 'vfat'
    I:Set page: 'flash_done'
    I:Set page: 'clear_vars'
    I:Set page: 'install'
    I:Set page: 'main'
    I:Set page: 'main2'
    I:Set page: 'wipe'
    I:Set page: 'confirm_action'
    I:Set page: 'action_page'
    Formatting Cache using mke2fs...
    I:mke2fs command: mke2fs -t ext4 -m 0 /dev/block/mmcblk0p34
    mke2fs 1.41.12 (17-May-2010)
    Done.
    I:Recreating /cache/recovery folder.
    I:Version number saved to '/cache/recovery/.version'
    I:Set page: 'action_complete'
    I:Set page: 'wipe'
    Wiping Dalvik Cache Directories...
    Cleaned: /data/dalvik-cache...
    -- Dalvik Cache Directories Wipe Complete!
    I:Set page: 'wipe'
    I:Set page: 'main'
    I:Set page: 'main2'
    I:Set page: 'advanced'
    I:Copying file /tmp/recovery.log to /sdcard/recovery.log
    Copied recovery log to /sdcard.
    I:Set page: 'main'
    I:Set page: 'main2'
    I:Set page: 'main'
    I:Set page: 'main2'
    I:fix permissions started!
    I:Mount: Unable to find partition for path '/sd-ext'
    Can't check permissions
    after Factory Reset.
    Please boot rom and try
    again after you reboot into
    recovery.
    I:Unmounting main partitions...
    Done.
    I:Set page: 'main2'
    05-17-2014 05:56 PM
  12. Golfdriver97's Avatar
    I do not know how, but perhaps the best thing to do is reflash a stock ROM, so that you can't least get the device up and running.
    05-17-2014 07:34 PM
  13. TCBCSM's Avatar
    Every ROM I have tried fails, I been at this for days.
    05-17-2014 07:51 PM
  14. wizzrah's Avatar
    You could try flashing an RUU.
    05-18-2014 02:48 PM
  1. Help finding a calendar app
    By bs03 in forum General Help and How To
    Last Post: 05-22-2014, 01:03 PM
  2. Samsung Galaxy Tab 2 10.1 New Charger Problem!
    By Jellal in forum General Help and How To
    Last Post: 05-20-2014, 12:10 AM
  3. videos pictures sd card help
    By Bob Walker1 in forum LG Optimus Series
    Last Post: 05-19-2014, 12:08 AM
  4. Need a good fanny pack, big enough for an S5 owner
    By Gandhi113 in forum Samsung Galaxy S5
    Last Post: 05-16-2014, 08:19 PM
  5. HELP! My phone won't root!
    By BreDoom in forum Droid RAZR MAXX HD
    Last Post: 05-16-2014, 07:45 PM
