1. Flames0824's Avatar
    Having hard time installing it. I already got the app down loaded. Just too instal keeps having error with saying "No Root"? If any one can help on adjustments let me know?
    08-04-2012 09:07 PM
  2. jetfactor's Avatar
    your phone didn't automatically come with it..?
    -sent from space.
    Encerspay45 likes this.
    08-04-2012 11:30 PM
  3. KingKhanOfficial's Avatar
    Your phone need to be rooted. Android rooting is the process of allowing users of smartphones, tablets, and other devices running the Android mobile operating system to attain privileged control (known as "root access") within Android's subsystem.
    Rooting is often performed with the goal of overcoming limitations that carriers and hardware manufacturers put on some devices, resulting in the ability to alter or replace system applications and settings, run specialized apps that require administrator-level permissions, or perform other operations that are otherwise inaccessible to a normal Android user. On Android, rooting can also facilitate the complete removal and replacement of the device's operating system, usually with a more recent release of its current operating system.
    As Android was derived from the Linux kernel, rooting an Android device is similar in practice to accessing administrative permissions on Linux or any other Unix-like operating system such as FreeBSD or OS X.
    Hope this help
    03-31-2013 04:08 AM
  4. zedorda's Avatar
    Hope this help
    You must not own this phone because it comes stock with Beats Audio and if he really does need to install it he must already be on a custom ROM which would be hard to do if he was not already rooted don't you think?
    03-31-2013 08:56 AM
