Results 1 to 5 of 5
- 12-15-2012, 09:42 AM
Thread Author #1
Poor battery when it comes to Phone Calls
I have only had this phone for 5 days now and not that much of a talker over the phone but I am completely baffled about the very low battery life on phone calls I was only on the phone for 20 some minutes and it dropped almost 20 percent. I thought this phone was supposed to have a 8 hour battery life of full talk time. With what I'm getting now I wouldn't be able to manage a 3 hour phone call without the phone dying. My old HTC Inspire 4g had excellent phone call battery life what happened to this one? it was still at 100 percent before making the phone call and when I looked at the battery indicator I saw that it had already dropped a significant amount in the little time I made the phone time. - 12-15-2012, 02:27 PM #2
Re: Poor battery when it comes to Phone Calls
5 days.
So first, you want to run the battery down to automatic shutoff. Then charge fully overnight.
Then use normally, charging when you can, but not worrying about it.
I've found that if you have wifi around, all the data shifts to wifi, which turns the cellular data connection off. Its a lot easier and less battery intensive to talk to the wifi router within 30 feet, than it is to talk to the cell tower a couple miles away.
Secondly, the discharge of this type of battery is not linear. Discharge from full to 80% happens much faster than discharge from 80% to 60%.
This is due to something called self discharge in LiPoly cells. So you might be measuring the self discharge rate rather than the actual talk time.
I've had days that I'm on the phone for well over 5 hours and still had a lot of battery left. Well over 50%.
The key is to keep the screen off as much as possible while in the call. I often use earbuds on long calls with the phone screen off and the phone in my shirtpocket or on the desk. - 12-16-2012, 02:31 AM
Thread Author #3
I know to let the phone all the way down. I have had many androids and know never to report bad battery or any battery life unless you did 3 complete battery drains. Also I don't have WiFi near by either. But when I'm not using the data I turn it off. So far ANY voice call kills my phone big time no matter if I'm on hspa+ or edge
- 12-16-2012, 01:35 PM #4
It's also known that voice calls are heavy battery users. As is the display. This isn't uncommon. Doesn't really seem out of the norm to me.
Forum Rules & Guidelines -- CLICK HERE
I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter. - 12-16-2012, 02:42 PM #5
When it comes to Android phones, why must there always be a compromise?
By thevaristy in forum General News & DiscussionReplies: 13Last Post: 10-13-2012, 01:36 PM -
How bad is bad when it comes to battery life?
By withravenoushunger in forum Verizon HTC ThunderboltReplies: 4Last Post: 03-02-2011, 10:08 AM -
Samsung! you're a lost cause when it comes to ANY update!
By denzillion in forum Verizon FascinateReplies: 2Last Post: 12-21-2010, 10:53 PM -
noob when it comes to this
By mustang229 in forum HTC EVO 4GReplies: 2Last Post: 10-26-2010, 09:39 AM -
What features are you waiting for when it comes to Froyo 2.2?
By CoryBantic in forum HTC EVO 4GReplies: 3Last Post: 07-30-2010, 01:29 PM
Reply
