Results 1 to 7 of 7
    Default Camera always using battery power?
    In the power consumption screen (battery use), it shows my Camera has used 16% of the battery, even though I took no photos and did not even open the camera app. Under Use Details, it shows CPU total = 0s.
    Does the camera always use battery, even if you don't use the camera itself?
    Also, are there any steps I could take to minimize the battery use apart from turning off auto-sync and lowering the screen brightness?
  2. Thread Author  Thread Author    #2
    Default Re: Camera always using battery power?
    Anyone have any input?
  3. #3
    Turning off mobile data when not in use also helps a bunch.
    If there's no path, we'll make one with these hands!
  4. #4
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Once you are done using the camera, pull up multitasking and remove it (kill it)... should solve your problem. If not, find it in settings>apps>camera and clear the cache.
    HTC One X AT&T
    Viper XL 3.2.4: ROOTED 2.20 : Hboot 1.14 : S-OFF!
    Nexus 7 - Dirty Rootbox v2.0
    If I helped you out, hit the thanks button on this post!
    Quote Originally Posted by Bizzle69 View Post
    I always clear everything when I'm done with it, and the camera still has a tendency to keep going even hours after I use it.
    I noticed that it goes away from the Power consumption screen after a full battery charge. I need to take a pic of my new TV, so I'll try clearing the cache and see what happens after that.
    Thanks for all the info so far. If anyone has anything to add, please do. All help is appreciated.
  6. #6
    do you have face unlock on? cause that uses the front camera
    Quote Originally Posted by llllBULLSEYE View Post
    Good thinking, but I have never used face unlock.
  1. SD card using battery power?
    By Anmanwar in forum Verizon LG Intuition
    Last Post: 11-12-2012, 05:09 AM
  2. AT&T HTC ONE X: Maps using high battery power?
    By oshogg in forum HTC One X
    Last Post: 05-26-2012, 02:27 AM
  3. display uses more battery power
    By drummerman2008 in forum Verizon HTC Thunderbolt
    Last Post: 05-09-2011, 12:12 PM
  4. How much battery power was LPP Facebook widget use?
    By Snareman in forum Android Applications
    Last Post: 12-05-2010, 01:02 AM
