I'm not sure if this question can be answered here, or if there's another forum appropriate for this type of question, but here goes...
Yesterday, I was using the Navigation app on my phone. It was a busy day, so I think I had left the app running. In my previous experiences with the app, it stays on until I exit the app. Previously, I remember the phone running really hot.
Anyhow, yesterday sometime in the afternoon, I took my phone out and found the screen off. Pushing the power button didn't do anything. So I figure it probably had a drained battery and I plugged it in the wall to charge. About three or four hours later, I pushed the power button again - just to turn on my phone and see if I had any missed texts/calls. Nothing - the screen didn't turn on, but the red LED light was on. So I left it charging through the wall adapter, and went to go do some research about the problem.
Next morning the red LED was flashing. I tried the power button again, but nothing happened. Then I got a little panicky and tried the different button configurations I had read about: holding down the power button for x amount of seconds, holding down the power button and volume down button simultaneously - but again, nothing happened.
Fast forward to tonight - I'm not sure if my phone is charging or not, or if something else sinister is happening to it. I pushed the power button down about a half hour ago, and the red LED turned off. I then, plugged my phone into my computer, and I got a dialog pop-up that said "Device driver was not properly installed" with the driver name "qhsusb_dload".
Any idea what this issue is? Or could you point me to further info somewhere?
Any help is much appreciated!
PS. I got my HTC One X just about 2 and a half months ago at the end of November. My phone isn't rooted, and the most "advanced" thing I did with it was put ADWLauncher on it.
