Lynn Elliott1
I tried this method and it did not work. After thinking about the overheating issue I thought about the power source. Most plugs have a wider neutral slot on the left and a smaller hot slot on the right. The HTC charger has two small plugs, so you can plug it in either way. I wasn't paying attention to how I was plugging it in. So, I decided to pay attention. I figured that the side of the charger that has "HTC" written on it was the top, so I've been making certain to plug it in so the neutral, left, slot was always on the left of the top of the charger. Since doing this, I have not had the overheating or the "no sim card" problem. Probably worth a try.
