- 03-11-2013, 11:26 AM
Thread Author #1
How to Fix HTC One X Overheating/Flashing RED while Charging [RAPID Battery Drain]
Is your HTC One X having POOR battery life? Does it heat up near the camera while the phone is on standby? Did your phone die then you plugged it in and there was a flashing red LED/Light
IF SO FOLLOW THIS
1. Charge the device for at least 10 minutes
2. With the device truly OFF (NOT ON STANDBY) , push in and hold volume up and volume down AND power button And HOLD for 2 minutes and let go once 2 Minutes has passed.
Doing this will calibrate the Circuit within the battery charging system.
Thanked by: - 03-11-2013, 02:41 PM #2
Re: How to Fix HTC One X Overheating/Flashing RED while Charging [RAPID Battery Drain]
Is this an HTC fix or something you figured might work for others?
- 03-16-2013, 03:02 PM #3
- 03-16-2013, 03:08 PM #4
- 03-16-2013, 10:08 PM #5
- 03-20-2013, 02:45 PM #6
- 03-28-2013, 02:58 AM #7
My one x was getting extremely hot by the camera and it wouldn't charge properly at all.I followed the instructions to a T and all is a lot better now. It's not overheating and is actually charging. Thanks for the post, it worked great.
- 03-28-2013, 11:36 AM #8
I have tried this twice now, and it brings me to an hboot menu. Choices included fastboot, factory reset, and a few others. Sadly, I didn't decide to post this until after I had chosen an option, so I don't remember them all.
Did I do something wrong to get there? If not, what option? - 04-13-2013, 04:12 PM #9
- 04-15-2013, 08:42 AM #10
Hi,
You say charge for 10 minutes, and then the next step is with the phone truly off - when the phone is switched off, should it still be plugged in to power, or not, or does it not matter?
Cheers,
Sam - 04-16-2013, 12:29 PM #11
- 04-16-2013, 02:02 PM #12
- 04-23-2013, 11:56 PM #13
Hello. I wasn't going to go through the trouble of registering just to post a comment, but this info was invaluable. I just opened my new HTC One X today, set it up and 2 hours later had my first 30 minute conversation. Well the phone got REALLY hot by the camera. So after the conversation ended I took the phone away from my ear to hang it up and the screen was just black. I couldn't get anything to come up and I figured the phone just died. So I hooked it up to charge but the charge light (at the upper right hand corner) didn't come on. The only light I could see was that really really dim one on the upper left. Anyway, after trying to hold down the power button to turn the phone back on, it would just make the bottom buttons flash on then off. So after my frustration I googled the problem and found this post. Everything works like a charm now after doing the 2 minute reset. Thanks a bunch!!!!
- 05-01-2013, 05:03 AM #14
First of all i already tried it and it didnt work unfortunetly, but i have to ask does it need root and when i do the second step does it have to stay on charge , and if so tell me what to do litrally please
- 05-01-2013, 05:21 AM #15
- 05-02-2013, 06:54 AM #16
- 05-03-2013, 08:59 AM #17
- 05-06-2013, 11:20 PM #18
u all plzzzzzz help me im in big trouble.
my htc have same condition. when i insert the charger only orange color light is blink. i tryied ur trick but when i press +and down key of vol... its being only blink some protocol is came and when i see deeply their was written h boot fast boot etc...and only blink this option. and handset not bieng on try to on during charging only htc blink without charger insert not being on what i should do plzzzzz tell me.why handset blink what is the problem plzzzzz tell me in detail or help by picture plzzzzzzzzzzzzzz..thx in advance to all. - 05-07-2013, 03:52 AM #19
- 05-08-2013, 11:28 PM #20
My phone life fully swiched of so i put it on charge now it is just flashing a red light it has been on charge for a number of hours and still will not turnon and just flashing a red light however i have pushed in the top of the phone and the volume up and down button and the white repair screen appared,and said battery life to low for light,then turned of what am i suppose to do???
Camera: How to fix one blurry lens?
By Ronen Yudzinsky in forum Virgin Mobile HTC EVO V 4GReplies: 0Last Post: 03-03-2013, 03:35 PM -
HELP! Phone reset in pocket - How to recover? (HTC One X)
By Treybap in forum HTC One XReplies: 7Last Post: 02-28-2013, 12:12 AM -
IGNORE;FIXED. CyanogenMod 10 won't flash to my HTC One V, please help!
By LunchBokks in forum HTC One VReplies: 0Last Post: 02-17-2013, 11:12 PM -
How to update htc one x at&t bought from america
By junedraza86 in forum HTC One XReplies: 4Last Post: 09-22-2012, 06:18 AM
Reply
