Results 1 to 11 of 11
    xeron72548's Avatar
    Posts
    Global Posts
    23 Global Posts
    Default HELP! Phone will not turn on or charge!
    Hello,
    I had put my phone to charge and when I came back to it 10 minutes later, it was off. I tried turning it back on but to no avail. The charging light will also not turn on. I cannot get into hboot or get my computer to recognize it. Please help!!
  2. #2
    chrisxpierce's Avatar
    Banned
    Posts
    Global Posts
    332 Global Posts
    Default Re: HELP! Phone will not turn on or charge!
    Try plugging into your pc, and not a wall outlet. Try a different wall outlet. Try a different USB Charging cable. Other than that, you'll need to contact HTC Support.
    xeron72548's Avatar
    Posts
    Global Posts
    23 Global Posts
    I have done all of that. I have contacted them and they said I would have to send it in. However, since my bootlader is unlocked, I don't know whether they will accept it or not
  4. #4
    I had a similar problem the other day, different phone. If a soft reset, popping the battery out and back in, using different outlets doesn't change anything, try using a car charger. It seems to have more power to jump start the charging process of an absolute dead phone. Be warned, though, it worked and so does my phone, but I am currently working out my phones problem of not being able to charge with a wall charger at all now.
  5. #5
    Scott Kenyon's Avatar
    Posts
    Global Posts
    2,204 Global Posts
    ROM
    MoDaCo Switch Beta 8
    People have been successful with warranty claims having unlocked bootloaders. I'd send it in and see what happens.
    Sent from my HTC One using Mobile Nations mobile app
    xeron72548's Avatar
    Posts
    Global Posts
    23 Global Posts
    Quote Originally Posted by akd1217 View Post
    The HTC One does not have a removable battery
  7. #7
    Gotcha. I didn't know for sure, but my RAZR doesn't have a removable battery either. The car charger still got it to charge and turn on when nothing else would though. Hope it helps.
  8. #8
    malikshuman's Avatar
    Posts
    Global Posts
    82 Global Posts
    ROM
    MeanRom
    Try holding your power button for 15 secs. It simulates a battery pull
  9. #9
    Hey! Guy's How to fix my phone because it wont turning on
  10. #10
    hello
    my phone's battery ran down and i had to connect it to power as usual,but after some time it went off and didnot power on again except when i connect it to power,it only flashes ared light at the top.whats wrong?
  11. #11
    Quote Originally Posted by nhallyma View Post
    hello
  1. Tether Fonepad to my laptop on AT&T
    By kinged33 in forum ASUS Fonepad
    Last Post: 12-23-2013, 09:34 AM
  2. Cannot get the update after unrooting phone
    By Jarrid Duchnowski in forum Droid RAZR M
    Last Post: 08-08-2013, 01:10 AM
  3. Recover Photos From Bricked Phone
    By jcgsville in forum T-Mobile Galaxy S II
    Last Post: 07-27-2013, 11:09 AM
  4. Latest update glitched up my phone.
    By mepres94 in forum Droid RAZR M
    Last Post: 07-27-2013, 11:08 AM
  5. White Light "of Death" Deleted SD Pics and Music. Please help!!
    By akd1217 in forum General Help and How To
    Last Post: 07-27-2013, 10:28 AM
B
