Results 1 to 6 of 6
    Default Speed dial problem. Please help.
    On my wife's HTC one can, this doesn't work.
    So everyone understand me, I'm thinking on the thing when you dial for instance 627 for Mark or 23 for Adam.
    How to turn this on?
    Sent from my HTC One 801e using Tapatalk
  2. #2
    Default Re: Speed dial problem. Please help.
    I can't say definitely for the HTC One, but for most Android phones these days, there is no longer a speed dial feature like that any more. It's replaced by the ability to place a Direct Dial widget on your homescreen or in a folder--just one tap, and it automatically calls that contact. The Direct Dial widget allows you to specify which phone number of a particular contact to call--the other Contact widget usually prompts you each time, asking you which number to call.
  3. #3
    Indyrobb's Avatar
    Posts
    Global Posts
    46 Global Posts
    Not sure I can be much help other than to say that mine works the way you described. It always cracks me up that I have to dial 666 to reach "mom". I can't find any settings to enable it disable the behavior.
    Hahaha... Can't see the reason why does this doesn't work...
  5. #5
    davidtm's Avatar
    Posts
    Global Posts
    677 Global Posts
    With the phone app opened to the keypad, tap the 3 dots to open the menu. Select Smart dial keypad.
    Sent from my cm_tenderloin using Tapatalk
  6. #6
    Indyrobb's Avatar
    Posts
    Global Posts
    46 Global Posts
    So I guess the question is whether the other phone is showing the full screen keyboard or the smart dial. At first I wasn't seeing the option mentioned above, but saw it after I switched to the full screen keyboard.
  1. Phone hacked? Please help !!!
    By alstoba in forum Software Development and Hacking
    Last Post: 03-17-2014, 04:23 PM
  2. Help identify Ad on screen
    By zebo427 in forum General Help and How To
    Last Post: 03-09-2014, 04:02 PM
  3. GS4 streaming music mutes problem
    By fstanuff in forum Samsung Galaxy S4
    Last Post: 03-07-2014, 03:34 PM
  4. Auto Dial Voicemail Passcode
    By k9luvr in forum Sprint Galaxy S3
    Last Post: 03-07-2014, 02:50 PM
  5. Light Scratch - Help
    By Floridadomer in forum Samsung Galaxy Gear
    Last Post: 03-07-2014, 02:04 PM
