Android system draining battery. 80% of my battery is used within 4 hours of charging...can someone please help me fix it?
I have been having a similar issue. I think it started after I upgraded to KitKat. I am thinking about doing a factory reset and to try to fix this issue. Has anyone else tried doing a factory reset to fix the battery drain issues? If so, did it work?
Dogs do u have a suggestion of a good app
I've been using clean master to clear ram but I have to do that like every hour to get battery life
I have to root my phone to use that not sure I want to do that
