05-18-2017 09:47 AM
30 12
tools
  1. TylerLV76's Avatar
    Seems this has been fixed with the latest update that includes Alexa
    03-22-2017 08:12 PM
  2. PaulQ's Avatar
    I'm not seeing the problem anymore either.
    However, I tried Alexa and then it wouldn't let me turn on Google's "Ok Google" always on setting. It just kept flipping it off when I swtiched back to my home screen after switching it on.
    I removed all of Alexa's permissions and force stopped it. I retrained my voice model. Now it works.
    03-23-2017 12:49 AM
  3. Ssdroider's Avatar
    I'm getting this pop up notification when I use my camera for video (also when I use the Ring app which also uses the microphone). I didn't get it in the past. What part of Google did I change that is causing this? Anyone know?
    The annoying part is that it will pop up repeatedly and I have to dismiss it to do anything with the underlying app.
    Attachment 253492
    (fyi - I just aimed the camera at my jeans for that picture)
    There is a simple fix to this. Go to Google now settings, go to voice settings and turn off OK Google detection from anywhere.... Hope that helps
    05-13-2017 04:48 PM
  4. freddyttt's Avatar
    but then you lose google now detection,. that said! this should no-longer be an issue as it was fixed with a recent update !
    05-14-2017 04:18 AM
  5. stantonian's Avatar
    I have the same problem with the Honor 8, but shutting off the ok google detection does fix it.
    05-18-2017 09:47 AM
30 12
  1. Replies: 6
    Last Post: 04-24-2017, 09:52 AM
  2. what is this notification icon
    By cd619 in forum Nexus 5X
    Last Post: 03-05-2017, 05:20 AM
  3. Where's the stop button for unauthorized add-ons?
    Last Post: 03-05-2017, 02:25 AM
  4. Replies: 1
    Last Post: 03-04-2017, 08:50 PM
  5. How to read grocery receipt data in android ?
    Last Post: 03-04-2017, 07:09 PM
