03-23-2017 12:49 AM
27 12
tools
  1. PaulQ's Avatar
    I'm getting this pop up notification when I use my camera for video (also when I use the Ring app which also uses the microphone). I didn't get it in the past. What part of Google did I change that is causing this? Anyone know?
    The annoying part is that it will pop up repeatedly and I have to dismiss it to do anything with the underlying app.
    (fyi - I just aimed the camera at my jeans for that picture)
    Martin Holl likes this.
    03-04-2017 08:12 PM
  2. TylerLV76's Avatar
    OK Google is set to detect from any screen. You'll have to turn. That off and set it to only detect in the app since the camera is taking over the microphone.
    03-04-2017 08:18 PM
  3. SoCalBIGmike's Avatar
    IDK, it happens in Hangouts too. It's a bug in early Nougat. Why the hell are we not on 7.1.1?
    03-05-2017 04:13 AM
  4. PaulQ's Avatar
    This is strange because I could swear it didn't appear before I reset the phone but it's quite possible I didn't have detect OK Google on from any screen. Hmm... have to weigh convenience against annoyance now.
    03-05-2017 03:06 PM
  5. TylerLV76's Avatar
    I find it just as easy to hold the home button and say it honestly
    03-05-2017 03:07 PM
  6. PaulQ's Avatar
    Oh yeah! That is a good compromise! Perfect. Thanks!
    03-05-2017 03:18 PM
  7. TylerLV76's Avatar
    No problem. I'm learning when you buy unlocked phones from someone other than the Samsung's, lg etc there's a few quirks here and there. So far on this one I haven't found anything too drastic that makes me want to go back to those other brands...Yet.
    03-05-2017 04:00 PM
  8. Yancy Evans's Avatar
    I think the Google Assistant update fixes the issue. On a lark I re-enabled "Ok Google From Any Screen" and I've yet to run into the issue with any of the apps I used before. Give it a whirl and report back.
    Yancy
    03-10-2017 10:39 AM
  9. Yancy Evans's Avatar
    Annnndddd... never mind what I just said, bug reappeared.
    03-10-2017 10:54 AM
  10. freddyttt's Avatar
    it does get annoying .
    03-10-2017 02:51 PM
  11. PaulQ's Avatar
    Awww... I just got to this post and was imagining being able to talk to my phone again without pressing a button.
    Silly Huawei.
    03-10-2017 08:23 PM
  12. Yancy Evans's Avatar
    Silly Huawei.
    I don't think it's Huawei, I think it's a program related issue. I had one oddball issue appear out of the blue. I started using Duo and thought I had disable Ok Google On Any Screen, and got the microphne nag. Went inside Assistant and physically disabled it backed out, went back in again, and once again it was enabled. Disabled, then went into the Google app and double-checked the "Google Now" Ok Google settings... sure enough it was auto-enabled and there was now way to turn it off. The only resolution was to delete my voice learning. Then I could disable the setting fully.
    I'm wondering if the Assistant and the Google app (which is part of the phone's base installation packet... there's no way to remove it) and are both fighting to use the mic. Just odd to say the least.
    03-10-2017 08:43 PM
  13. Dimas de Leon's Avatar
    I just started getting that same popup when use the Sound Meter tool.
    Attached Thumbnails "Camera currently recording audio...." notification - How do I stop it?-screenshot_20170310-205002.jpg
    03-10-2017 10:51 PM
  14. PaulQ's Avatar
    I think it's anything that tries to grab the microphone. For some reason, it wants to tell you that you can't say "OK Google" while you are using the microphone for something else. Clearly it wasn't planned because it's all in program mishmash rather than a friendly notification using layman's vocabulary.
    03-10-2017 11:28 PM
  15. Yancy Evans's Avatar
    Pretty sure this is an Goggle Assistant/Google Now software issue. If you go to Google's Assistant forums there are a lot of devices reporting similar problems. Some Samsung S6 users have been reporting the mic refuses to shut off and keeps recording audio, other Samsung users are reporting they cannot open apps because Ok Google is in use.
    03-11-2017 10:09 PM
  16. ELsemary's Avatar
    I have that error too .
    It start when I start use OK Google .
    Any app use sound like camera or call recorder this message appears and stop it . It stop recording vedio and calls .
    Go to :
    Setting } Apps } Google } Permission } deactivate Microphone .
    So that will deny Google app from using Microphone and this message will stop appear .
    03-13-2017 10:55 PM
  17. Yancy Evans's Avatar
    Go to :
    But that kind of defeats the purpose of having Google Assistant... the hands free aspect of it.
    03-14-2017 01:42 PM
  18. OLD_HATCH's Avatar
    So other than disabling microphone use for ok Google is there any other way to stop this pop up message from appearing in every app that uses the microphone?
    Anyone know if formal bug reports have been filed with Huawei?
    03-19-2017 03:57 PM
  19. rjl2's Avatar
    This is what I want to know. I initiated a Duo call last night and got the pop-up. Even after dismissing it, it still kept popping up. It was extremely annoying. There was a connection issue and, somewhat surprisingly, when the other party called me back, I did not get the pop-up.
    Anyway, I hope someone figured out what's going on.
    03-19-2017 05:04 PM
  20. freddyttt's Avatar
    I think this is a Android 7 software problem not Huawei....
    03-20-2017 03:04 AM
  21. CWens's Avatar
    i've solved by disablig 'voice wakeup' in voice control menu.
    Let me no know if it works for you
    03-20-2017 09:39 AM
  22. freddyttt's Avatar
    thanks a little more info please?? also does this fix render google voice either google now or AI usless ??
    03-20-2017 03:11 PM
  23. PaulQ's Avatar
    Yes, I too would like to know what you are referring to. Thanks!
    03-21-2017 01:42 AM
  24. rjl2's Avatar
    If you're talking about Settings -> Smart assistance -> Voice control -> Voice wakeup, that settings is already off for me (and was off when the notification kept popping up in Duo) so I don't think that's it for my issue. Glad it worked for you though.
    03-21-2017 12:46 PM
  25. PaulQ's Avatar
    Same here. It's off. Always been off. Have problem.
    03-21-2017 08:50 PM
27 12
  1. Replies: 3
    Last Post: 03-05-2017, 12:49 PM
  2. what is this notification icon
    By cd619 in forum Nexus 5X
    Last Post: 03-05-2017, 05:20 AM
  3. Where's the stop button for unauthorized add-ons?
    Last Post: 03-05-2017, 02:25 AM
  4. Replies: 1
    Last Post: 03-04-2017, 08:50 PM
  5. How to read grocery receipt data in android ?
    Last Post: 03-04-2017, 07:09 PM
