What has been your experience so far. Received any software Updates? Thinking of getting one and looking owner's experiences.
I have it, and love it... Hard to find a flaw with it... I'm using it in Australia but bought it from ebay (c636 model).
As far as updates go, I just recently updated to the latest version by using Huawei firmware finder which is an app in the playstore.
Unless you're expecting regular updates such as the pixel/nexus line up, I wouldn't let that deter you from buying the phone. Feel free to ask any questions!
If you are NOT in USA the P10 Plus is worth a look, just came out.
Huawei has admitted the various models are had to distinguish between even when buying. And sellers on various sites seem ... questionable.
Mate 9 is excellent. Tad on heavy side if you hold it for long periods.
Hi,
I now have both the Mate 9 and Mate 9 Pro after selling off a selection of older HTC and Samsung Mobiles.
Like them both very much. Prefer the Pro, simply as it is smaller and handier. Aesthetically the Pro is better. However, although the Pro generally has a better screen, the 9's screen is a little easier to see in bright sunlight. It is subjective, but I think the speaker on the 9 is a tiny bit better as well.
Generally really impressed by build quality and software of both phones. Wish the software updates in the UK were more timely though.
Cheers
Hi Marsh.
Above i wrote that i was thinking about getting it. Your review just pushed me over the "edge" (get it? I have a samsung s7 edge)
I will buy the mate 9 pro!
Hi,
I had the Samsung S6 edge plus.
The Mate 9 Pro has better telephony, build quality, just about better everything. The only factor that the Samsung was better at was sunlight legibility.
One thing to keep in mind, is if the pro is officially on sale in your country. It isn't in the UK and I took a gamble buying on Ebay
