Hi!
I purchased a brand new P9 32GB two weeks ago and im really happy with it most of the time. I like to save both battery and money by turning off mobile data and background update for most of the apps, even the system apps and keeping the most important ones on. This works great most of the time but i got a slight problem with it. I have mobile data turned off for Google Play Store. If im on mobile data with wifi turned off and i need a app, i will go into settings to turn on mobile data for Google Play Store. But thats when the strange thing happens.. Mobile data wont work for Google Play Store (or any other app). Its turned on, i open the app but it tells me i need either a wifi connection or mobile data connection. The only way to fix this is to turn on mobile data and background update for every app and restart the phone. My friend also bought the exact same model but from a different store, and he also experienced this problem. The method by enabling all the apps and restarting the phone usually worked for him, but last time it didnt work at all so he had to return it to the store and get a new phone. I've also been in contact with Huawei's customer support but they hadnt even heard of this problem.
So im asking here. Does anyone know what could cause this problem?
