1. Couck#WN's Avatar
    I just bought a Droid Incredible 2 and I am looking for a slim extended battery. I have found a few and just wondering what the thoughts here on the forum are. I had the Seido 1750 for my OG Dinc, it worked well for a while then seemed to die fast. What are you guys doing?
    Seido 1750?
    And I found this but not sure if it will work in the DInc 2
    CHICHITEC SPRINT HTC EVO 4G BATTERY 1900mAh high capacity OEM Verizon Incredible Droid TOUCH PRO2 HTC Japan Tsunami Earthquake
    Someone please help with this. Thanks
    PS. The phone came with the 2150 with new back but its just too bulky for me. I dont want that thick of a phone
    07-20-2012 05:11 PM
  2. dobermans rule's Avatar
    I would personally use the Seidio one. It might just be about 300 (give or take a little), but any little bit helps.
    Sent from my ADR6350 using Android Central Forums
    08-30-2012 03:53 PM
