I was in my clockworkmod recovery and i accidentally hit format system and now I'm stuck on HTC screen. How do return to original 2.3.4?
If you were running a ROM, just reflash it. You basically just formatted your OS partition, data and everything else is still there.
Or, if you have a Clockwork backup of your system before you formatted it, do an advanced restore and just select system. That'll just restore the system partition of your backup without overwriting anything else.
