Results 1 to 8 of 8
- 01-07-2012, 12:22 PM
Thread Author #1
- 01-07-2012, 01:38 PM #2
Re: accidentally formatted my system. please help
If you were stock and want to stay stock, you'll probably have to flash an RUU, but that'll overwrite your CWM recovery and you could loose your data. If you were running a ROM, just reflash it. You basically just formatted your OS partition, data and everything else is still there.
Or, if you have a Clockwork backup of your system before you formatted it, do an advanced restore and just select system. That'll just restore the system partition of your backup without overwriting anything else. - 01-08-2012, 06:29 PM
Thread Author #3
- 01-13-2012, 04:03 PM #4
- 04-01-2012, 03:46 AM #5
- 11-11-2012, 04:43 AM #6
- 12-17-2012, 05:42 AM #7
- 12-17-2012, 05:40 PM #8
Reply
