DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 2 of 2
    Default Help getting my phone to work again
    So I had MIUI 12.9 running my phone and for some reason whenever I played music for an extended period of time (~20 min+), the phone would freeze and I had to pull battery, reboot, etc. I had recently unlocked it using HTCDev unlock bootloader, so I figured I would try following steps using tacoroot to gain s-off. To do this, I need to relock the device, so I did fastboot oem lock. Well it locked the device alright, but now I can't do anything. In bootloader it says *security warning* then *relocked* underneath. I can't get into CWM, factory reset, or anything. When I have my phone plugged in to my computer, it doesn't show up in adb devices. I'm not sure what to do from here. If I could get it to show up in adb devices after booting into the bootloader I could probably fix it, but I'm not sure how.
    Any help would be great.
    EDIT: Downloading the stock gingerbread rom and flashing that as PG32IMG...didn't think of this until now but hopefully it works
    EDIT2: Didn't work. Even with the latest gingerbread stock rom with .98 hboot it says main version is older
    EDIT3: Finally got my phone to show up and just unlocked again using HTC unlock process. Got a rom flashed on again and working so this can be closed
  2. #2
    sjpritch25's Avatar
    Posts
    ROM
    MIUI 1.11.4.1
    Default Re: Help getting my phone to work again
    When your in hboot what radio do you have. Because the latest firmware and radio are causing the most issues.
    Droid Incredible 2 (S-OFF)
    Android Version 4.2.2
    Evervolv-Conor-3.2.0-Nightly-2013.05.05
    Kernal 3.076-evervolv nightlies
    Oc 1.4mhz
