Results 1 to 9 of 9
    Default Body Glove
    Hey everyone,
    Has anyone else had any issues typing out messages with the body glove on? I just went to my local VZW store and picked one up.
    It's the rugged looking one that snaps on like a clamshell. It looks great, feels great but I don't know if I like how difficult it makes it to use the edge keys in portrait mode.
    On a side note, have any of you noticed it having a hard time noticing touch inputs when directly in the sunlight? I noticed that if I put one hand in front of the phone to cast a shadow on it, I can use my other hand to make the input that I need. Of course, this does make it difficult to do since we humans only have 2 hands, unlike some droids I know.
  2. #2
    Default
    I've run into that issue, but I love the case too much. Damn fat fingers!
    Default
    I almost wonder if I took a dremel or an x-acto and just trimmed the edges down a little if that would help. But I don't know how good it will look.
  4. #4
    tony bag o donuts's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,828 Global Posts
    ROM
    BB JB
    Default
    Quote Originally Posted by sklemp View Post
    Don't.
    I tried that with my curve.....then the rubber started to peel and then I couldn't help myself from tearing it off and then I switched to an innocase.....
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  5. #5
    Default
    Quote Originally Posted by tony bag o donuts View Post
    Don't.
    Damn I was about to do the same. Thanks for the SAVE!
    Default
    Don't.
    Thanks, I was going to try it tonight, glad I didn't.
  7. #7
    Posts
    Global Posts
    6,828 Global Posts
    ROM
    BB JB
    Default
    No problem.....
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  8. #8
    Default
    Any other 3rd party case makers going to make a case? I love Incipio and Incase. I just wonder how long the wait is.
    Default
    This case is awesome, and after using it for a couple of hours and sending about 100+ texts I can say that it took some getting used to but I think I will keep it. It gives me more to hold on to, plus it protects the phone. Not to mention I can place it in my generic car mount without it adjusting the volume settings.
