Results 1 to 9 of 9
- 05-10-2010, 05:47 PM
Thread Author #1
Seidio holster fitting around the Body Glove?
I like the solid protection and feel of the Body Glove, but I prefer the holster of the Seidio. (the one for the innocase)
Do you think the Seidio holster that is made to go with the Innocase, would fit around the Body Glove? - since the Body Glove is a bit thicker than the Innocase - 05-10-2010, 05:51 PM #2
My guess is no.
- 05-10-2010, 06:15 PM #3
if you get the clip holster that is for the seidio case i bet it will. i know pretty much all my cases i trying worked on my seidio storm 1/2 spring clip holster
- 05-10-2010, 07:33 PM
Thread Author #4
I guess I'm just hoping that the Body glove isn't that much thicker than the Innocase that fits in the spring clip.
In not, then the Silicone case should fit nicely. I just think that the body glove, and silicone case, seems to offer a little more bump protection than the Innocase. - 05-10-2010, 08:27 PM #5
I say no. The seido usually has a catch on the back of the case for the spring clip holster. Not only that, but it is designed to fit into the spring holster. The body glove that I have for the incredible does not have a catch in the middle and is thicker than the seido will be. I had the seido fo for the BB and I do have the body glove now for the Incredible, but will be moving up to the seido as soon as it ships....it is on the web site, take a look. or the otterbox. As for drops...that is what the insurance is for
George
was Stormfail
then: HTC Incredible...NOW BIONIC - 05-10-2010, 09:32 PM
Thread Author #6
Yeah, love the fit/size/operation of the Seidio.. Have seen the web site..... "coming soon" for the Inc.
will def get it asap - 05-11-2010, 09:49 AM #7
They have now even listed pics of the case and holder. Not sure I like what appears to be overlapping of the case.
George
was Stormfail
then: HTC Incredible...NOW BIONIC - 05-11-2010, 12:34 PM #8
- 05-11-2010, 06:54 PM
Thread Author #9
Reply
Wow, mine only gives directions.
