KB3MMX
Batterystats.bin
Should I delete that batterystats.bin file if i changed my Dinc to the 2150Mah battery>?
Where can I find that file to delete?
I guess that once it is deleted, the battery gauge might be more accurate or something?
Thats the one I got and after rooting swapping to the Undervolted Hydra Kernel (less power usage by 100 / 25mv respectively) and recalibrating the battery by deleting the batterystats.bin I can get 17-18 hours of it under pretty heavy usage. Normally, since everyday varies, I manage between 14-16 hours on it.
