I purchased a 3500mah battery for my incredible on ebay for really cheap. It works great, but im not liking the battery door it came with. Anyone know where i can get an oem battery door for this battery size or maybe a seidio battery door? Thanks.
Although I liked the extended battery I returned it. There is not a case that fits their extended .
I bought this case from this company. I was peased with their service.
What you are really getting is a Verizon case with the back cut out. The extended door is not covered.
I am satisfied with this compromise case
Extended Battery Fit Silicone Cases for HTC Incredible
Please note: It will NOT work with any non-HTC made extended batteries, including Seidio's 3500mAh extended battery.
