1. SpaceHippie's Avatar
    I purchased a 3500mah battery for my incredible on ebay for really cheap. It works great, but im not liking the battery door it came with. Anyone know where i can get an oem battery door for this battery size or maybe a seidio battery door? Thanks.
    01-03-2011 12:32 PM
  2. Jude526's Avatar
    I ordered my extended battery from Verizon and it comes with the door. Might want to check out a store or call customer care. I will be receiving mine on Wed
    01-03-2011 01:52 PM
  3. PvilleComp's Avatar
    For a while Seido had a replacement 3500 door on their site for order - you might want to give them a call.
    SpaceHippie likes this.
    01-03-2011 06:02 PM
  4. Jude526's Avatar
    Although I liked the extended battery I returned it. There is not a case that fits their extended .
    01-09-2011 03:30 PM
  5. PvilleComp's Avatar
    Try the Sedio 3500 - the door comes with it and I've had it since July and love it. Got one for my wife's DInc as well!
    Whoooo Hooooo Post 1000!
    01-09-2011 06:00 PM
  6. teddeli's Avatar
    I bought this case from this company. I was peased with their service.
    What you are really getting is a Verizon case with the back cut out. The extended door is not covered.
    I am satisfied with this compromise case
    Extended Battery Fit Silicone Cases for HTC Incredible
    01-10-2011 10:12 AM
  7. aweaver33's Avatar
    From the link provided:
    Please note: It will NOT work with any non-HTC made extended batteries, including Seidio's 3500mAh extended battery.
    Has anybody found a case that fits the Seidio 3500 other than the POS that Seidio tries to pass off as a case that doesn't wrap around to the front?
    01-21-2011 12:15 AM
  8. Prezp127's Avatar
    i would get that case but it offers no protection except from scratches. wish some company would come out with an extended battery case other than that silicone piece of crap
    05-16-2011 06:40 PM
