Ok, I just need some confirmation that what I'm about to have to do is correct, since I'm in a pickle. I've read lots of threads everywhere that have bits and pieces of what to possibly do, but I want to make sure I truly understand.
I'm running CM7 #170, S-off. Went to do a nandroid through Rom Manager (most recent update) and updated CWM to latest version, getting ready to flash Nils BG to try it out. When I selected to backup current ROM, wipe data/cache, it immediately went to HBoot and flashed 'no images found'. Every time I select recovery or clear storage, it goes to the white boot screen and no further. I was able to go to Fast Boot, select Power Down, and CM7 booted up. I tried it a couple of times, same thing. Went to Rom Manager and reflashed 3.07 and 3.08, trying both (I have AMOLED, so I'm thinking .07 is the one I'm supposed to use?). Still same results. Tried to backup in Rom Manager, same thing.
So, from what I've read, I have to possibly reformat my SD card in the computer (does it matter that I used a Mac with Unrevoked Forever?). Download Doug Piston's PB31IMG, put it on root of SD (after formatting), flash through HBoot (go to recovery at that point, right?). Then I download the recovery of CWM from dougpiston and flash that? This is where I get a little confused and feel like there are gaps.
Sorry it's so long, but I truly like to understand what I'm doing, instead of just trying a couple things, going back and trying to undo, etc.
