Results 1 to 5 of 5
- 10-24-2011, 05:19 PM
Thread Author #1
help with cm7.1 gps
my damn gps signal keeps going in and out on cm7.1 i have no idea what to do, it loads then it goes to the big blue bubble, then the bubble goes away stays where it loaded and it doesnt move, mind you i'm traveling at 75 mph. what should i do? i'm done with flashing different roms only to find a fault i just want this one to work
- 10-24-2011, 07:31 PM #2
Re: help with cm7.1 gps
I've never had a problem with GPS on CM7, but I know others have. Try GpsFix from Android Labs in the market. I've read where it's fixed GPS issues for many folks.
Hope this helps.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig. - 10-24-2011, 08:01 PM #3
Are you on the latest nightly? What different ROMS have you tried?
- 10-24-2011, 09:43 PM
Thread Author #4
- 10-25-2011, 09:30 AM #5
You may want to bump up the latest nightly with a clean install and see if that fixes it...after you make a nandroid first of course.
"I drank what?" -Socrates
Reply
