Hello,
First I should say that tonight was the first time I've even touched a Dinc I, I've had a Droid X and Nook Color and have been playing with ROMs for the past year so I consider myself proficient, but no expert.
The Dinc I was given was in a white screen boot loop. It would vibrate show a white screen with Droid Incredible on it and then power down only to repeat the process over and over. I was able to boot into Hboot and placed a GingerBread PB31IMG.zip file on a FAT32 formatted microSD card.
When I booted the DINC found the update and did it's thing to check the update. HBoot then asked if I wanted to apply the update, I choose "Yes" and the phone rebooted itself and started the update process. I went to work on another project and came back to show the update had finished saying "Update Failed". When I viewed the update progress one of the items was listed as "failed", it was the first item and said something like "Partition Structure", I can't remember.
Hboot advised a reboot which the DInc did, but it did not power back up. I can get no lit led on the front of the phone when connected to a charger and the phone will not attempt to boot either into hboot or the OS.
Any ideas?
Thanks!
Dr.Bones
Any ideas?
Thanks!
Dr.Bones
