Results 1 to 4 of 4
    sdc5364's Avatar
    Posts
    Global Posts
    71 Global Posts
    Default need help rooting
    have a dinc and am tryng to root. I have rooted before but hit a wall. It is running android 2.3.4, Radio 2.15.10.07.07, and unrevoked will not root, any help or ideas?
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: need help rooting
    Unrevoked does not work with Gingerbread. You need to either use the HTC Bootloader unlock tool or restore back to Froyo and then root. After that you can flash one of the rooted Gingerbread ROMs. and upgrade the Radio.
    Here's a link for the HTC Bootloader unlock:
    DROID Incredible Bootloader Unlocked by HTC
    Here is a link where you can download a stock Froyo build if you want to use the downgrade.
    Hope this helps.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
  3. #3
    hsbr's Avatar
    Posts
    I had the same problem, but I am way too lazy atm to downgrade or do the research on another method, so i gave up.
    Now I'm having problems with the phone freezing and restarting itself while sending texts. Is there a way to solve this problem without a factory data reset?
  4. #4
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Try clearing cache and data out of the messaging app. You will lose your text's if you clear data out of the app, so you may want to see if just clearing the cache works first.
