DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 2 of 2
    Default power button /optical mouse on HBOOT
    I am attempting to flash a new Rom on my DINC. When I get into the recovery screen in HBOOT. The volume works for up and down, but power button just turns off the screen and optical mouse doesn't do anything. Any Ideas?
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default Re: power button /optical mouse on HBOOT
    Are you in recovery or hboot? In recovery the power button is thqa back button in HBOOT it's the OK/Select button. The joystick button in recovery should be OK/Select.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
