need help changing boot animation OS X
jared916
108
i need help changing my boot animation. ive looked at tons of other sites and videos but none of helped. MOst are for windows and those cant help. i have downloaded the SDK and fastboot and put them into tools. i have also placed my bootanimation.zip in there as well. but this is where i am stuck. i dont know what to do when it come to running commands in terminal. adb never works for some reason. so can anyone help? i really appreciate it. a step by step guide would be great
omgbeav
125
www.beavsgraphics.com
For the most part, all the current devices support the same screen size (Incredible, Galaxy S, Droid, Nexus One, Evo etc.). Did you try what I linked in the previous post?
jared916
108
Yes and it works. But I went to droidboots.com and tried one from there and I couldn't get those to work
Qazme
2,703
26
If it comes up just black, it's because the file didn't push correctly. All you have to do is load up your terminal. But your bootanimation.zip / android_sound.mp3 (if you have one) in the same folder as your sdk/tools/ folder. Then issue.
adb push bootanimation.zip /data/local
Hit enter. Reboot your phone. All the boot animations will work on any android device, with the one exception being if they are full screen animations and the phone them came from have either a bigger screen or smaller screen it may look off a bit. I'm currently using the Droid X boot animation on my Incredible for instance.
jared916
108
Sometimes I push then it says a certain amount of data was copied in a certain amount of seconds then I reboot and its not there. Just black screen
JTEastwood
104
i have found some boot animations out there with jacked up resolutions in the info file that cause the screen to stay black rather than run the file.
it can be edited to the right resolution for most of them.
JTEastwood
104
Is there an easy way to push boot animations with clockwork mod
yeah just push your bootanimation.zip from your sdk tools folder
from tools
shift right click -- open command prompt window
adb push bootanimation.zip \data\local
adb reboot
i had to boot the phone into recovery a few times with clockwork to get the file to push but that should do ya...
guylenn49
