Results 1 to 6 of 6
    Default Cant get unrevoked3 to work...help!
    I have tried several times to use the unrevoked and every time it says loading recovery image.... do not touch your phone....after about 30 mins still nothing. I even waited a hour once....any ideas on whats going on?
  2. #2
    Default
    If you are using windows have you installed the hboot drivers first? It talks about it on the unrevoked site under more info.
  3. #3
    Qazme's Avatar
    Posts
    Global Posts
    2,956 Global Posts
    ROM
    Bugless Beast 4.1.1
    Default
    You need hboot drivers installed for your phone and your phone in usb debugging mode. Try this:
    The Storm has cleared to an Incredible day! I ate an IceCream Sandwhich. Still needed JellyBeans. ;-)
    NEXUS!!!!!!
  4. #4
    bigslam123#AC's Avatar
    Posts
    Global Posts
    1,278 Global Posts
    ROM
    Stock
    Default
  5. #5
    Default
    Once you get their drivers working and put your phone into USB debug mode (important) it should only take a little while.
  6. #6
    schrack3000's Avatar
    Posts
    Global Posts
    54 Global Posts
    ROM
    Rooted Stock
    Default
    You also need to uninstall htc sync from your computer. I just rooted yesterday and it kept hanging up until I removed it. After that it worked on the first try.
