1. streetglyden's Avatar
    Well, I finally took the plunge rooted and updated the Skyraider 2.5.2 after Froyo wasn't released on the 18th. It has been working great but I have started to notice that my wireless connection keeps dropping at my house. I haven't had a problem with it until this morning.
    I have restarted the router and I don't have any problems with any of the other devices in my house.
    I am running the 2.05 radio because I am a little reluctant to use unrevOKEd forever and do something to the phone that cant be undone as of now.
    When I started having problems I flashed to Kingxkernel #2 but I didn't notice any change so now I am back on the stock kernel.
    If I reboot I can connect to wireless and get on the Internet. It will then drop in about 10 seconds, search again and pick it back up but even though it shows connected I can no longer access any webpages, market, etc... It will then drop again and continue this process.
    Are there any log files that I can check that would show me what is happening?
    Has anyone had similar problems? And lastly any suggestions?
    08-21-2010 09:14 PM
  2. TDAY#AC's Avatar
    Sorry man. It sounds like I have the same setup as you do/did. I'm running 2.5.2 with sense and the #2 kernel. I also have the 2.05 radio and I haven't had this problem. Maybe flash to a working backup then try installing skyraider again.
    08-21-2010 09:54 PM
  3. SpartanDroid's Avatar
    Someone please help because I am having the exact same problem. It says I am connected but I'm not able to get on. I have felt like wireless and mobile connection has gone down with skyraider. My camcorder keeps causing my phone to reboot too
    Sent from my ADR6300 using Tapatalk
    08-22-2010 01:23 AM
  4. velopirate's Avatar
    I really don't think these problems have anything to do with SkyRaider. I'm running SkyRaider 2.5.2 with baseband 1.25.00.07.28 and have never had an issue. My kernel is KingKlick's #2 kernel. Why are you so quick to blame this on the ROM? Have you flashed a different ROM to see if you have the same problem?
    08-22-2010 03:01 AM
  5. Qazme's Avatar
    Did you clear the cache and data when installing the ROM? That would be the only thing I would imagine would muck it up. Of course the radio has much more to do with WiFi and 3G than the ROM.
    08-22-2010 04:15 AM
  6. streetglyden's Avatar
    I'm not quick to blame it on the ROM... I think it could also be the radio. Those are the two changes. I have tried the two kernels and still had the problems.
    08-22-2010 07:41 AM
  7. streetglyden's Avatar
    I did clear the cache and data when I installed the ROM.
    08-22-2010 07:42 AM
  8. velopirate's Avatar
    Then it's not SkyRaider's ROM. Try upgrading your radio to the 1.25 version to see if that clear's it up for you. Be cautious and patient when updating a radio. You shouldn't have any issues at all, but don't do something crazy like pull your battery before it is complete. Good luck!
    08-22-2010 08:20 AM
  9. SpartanDroid's Avatar
    Well I just have the stock radio in my phone right now. I think I should probably upgrade it to see if that fixes the problem. Does anyone have the link with instructions cuz I am not using unrevoked forever since its unreversible.
    Sent from my DInc using Tapatalk
    08-22-2010 12:31 PM
  10. velopirate's Avatar
    If you're willing to go the unrEVOked forever route, there's a good discussion on this over at the xda developer's site that covers about anything you would ever want to know.
    08-22-2010 01:49 PM
  11. Qazme's Avatar
    Whoa wait, you still have a 1.00 radio on SR 2.5.2.......that may be your issue. Don't run 2.2 with 2.1 radios. And never run 2.1 with 2.2 radio there are compatibility issues....
    08-22-2010 01:51 PM
