Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Need help
    Hey everyone, last night I tried rooting my phone using unrevoked and everything was working fine until I tried using Hydra's kernel. Now my phone is stuck in a boot loop. It will just show the HTC green and white screen and then it goes to the verizon screen and then starts again with the HTC screen. Please help me fix this.
  2. #2
    sloan31's Avatar
    Posts
    Global Posts
    626 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    boot into recovery and flash another kernel
  3. #3
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Its OK to pull the battery on a kernel boot loop.. read hydras site... my phone had boot loop with all the hydras.. try the kingxclicks
  4. #4
    Qazme's Avatar
    Posts
    Global Posts
    2,956 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Bugless Beast 4.1.1
    Default
    Get the king #1 BFS kernel. Boot into recovery mount sd storage. Once it pops up copy it over to your SD card. Unmount sd storage. Flash the kernel, be happy.
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I've tried other Hydra kernels and one from King. Still same thing. I put the new zip on my memory card and go to recovery and once I'm done it's still the same loop.
    Tried all of these and same thing
    http://kingxklick.com/forum/viewtopic.php?f=25&t=154
  6. #6
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Wicked96ta View Post
    Did you try the stock hydra :
    Hydra Kernels - Stock Speed Undervolted Kernels
    If that doesnt work you will have to do a nandroid restore and you will be back to rom stock
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by NoobTube View Post
    How do I do the the nandroid restore? Been at this all day
  8. #8
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    the first question would be did you do a nandroid back up...if you did then hboot(power vol down)->recovery->nandroid->restore->you should have a list of dates to choose from, pick the newest
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ummm say I didnt make a back up, am I screwed?
  10. #10
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    you should have at least one...did you look in the nandroid menu...what rom are you on?
  11. Thread Author  Thread Author    #11
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes i did look in there and there is nothing. I am running the stock rom. All I did was use unrevoked to root and tried installing a kernel from hydra and that's when the boot loop started.
  12. #12
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    are you running froyo?
  13. Thread Author  Thread Author    #13
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    No, regular 2.1
  14. #14
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  15. Thread Author  Thread Author    #15
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Not working either, same boot loop.
  16. #16
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Go here and download the stock kernel...
    http://hydrakernel.cz.cc/
    support page..READ and click "here"
  17. Thread Author  Thread Author    #17
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Now it keeps getting stuck on the HTC Incredible screen, the first one.
    BTW, I really do appreciate you taking time to help me.
  18. #18
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    What do you mean "keeps"? It gets stuck and you turn it off or pull the battery?
    Good news is you are not bricked, bad news is I am not quite sure where to go from here. give me a few minutes
    You are very welcome, I am helping you as others helped me...but PLEASE please READ READ READ you will save yourself alot of stress
  19. #19
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    last resort is always to undo root...not sure what you will lose since you did not use nandroid or titanium back up but your phone will work,
    scroll to the bottom of this like and FOLLOW instructions to undo root...then follow his instructions (they are very good for beginners) to root again or anything else you want to do
    Howto: Root the HTC Droid Incredible - Technology - Jonamerica.com
    you are probably getting boot loop B/C you are putting a froyo kernel on an eclair rom w/ a stock 1.xx radio
  20. Thread Author  Thread Author    #20
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I know, I'm trying other forums to see if there is anyone who had the same issue as me. What I do is that if I get stuck in a boot loop or a freeze I have to do a battery pull. I am using my brother's Eris to put the zip files on my SD card because because my phone will not connect, and then once I'm done copying and pasting the zip, I put the SD card back in my phone. Then I hold down Vol down and power key. Everything was fine when I rooted with unrevoked, it was until I tried installing the Hydra kernel that everything went haywire. I never installed a custom rom or anything like that.
  21. #21
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    quick questions, did you try the kernel from the link I posted from the support tab? or the kernel tab?
  22. Thread Author  Thread Author    #22
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes I tried all the ones you posted or suggested. The stock one froze at the first boot screen. All the other kernels would just boot loop.
  23. #23
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    then you may have to unroot..you will keep info on sd but lose apps possibly
  24. Thread Author  Thread Author    #24
    Wicked96ta's Avatar
    Posts
    Global Posts
    60 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have no problem with that but I downloaded the unroot file in the link you posted but when I choose it in clockwork recovery from my SD card nothing happens.
  25. #25
    NoobTube's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    i am shocked this kernel didnt work...
    Hydra Kernels - Support
