Results 1 to 15 of 15
    FD2
    FD2 is offline
    FD2's Avatar
    Shadow Lurker
    Posts
    Global Posts
    376 Global Posts
    ROM
    Stock
    Default Add reboot and recovery to your power menu options.
    Credit to snq- from XDA for making this possible. This works on SR, Virtuous and should work on most other FROYO, SENSE DEODEXED roms ONLY!!!!!
    Onto what it does:
    *Download, place on SD card reboot into recovery, select 'install zip from sd card', select 'choose zip from sd card, find the zip and install.
    ***Remember to make a nandroid first.
    I'm not a star, somebody lied
  2. #2
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    Sweet!
    I'm the ROOT man
    G Talk: Upstreammiami3o5
    Let me help you ROOT your phone
  3. #3
    Qazme's Avatar
    Posts
    Global Posts
    2,956 Global Posts
    ROM
    Bugless Beast 4.1.1
    Default
    God I love Cyanogen I love these menu options make it so much nicer when needing to get to recovery or the bootloader!
    The Storm has cleared to an Incredible day! I ate an IceCream Sandwhich. Still needed JellyBeans. ;-)
    NEXUS!!!!!!
  4. #4
    mclarryjr's Avatar
    Retired Moderator
    Posts
    Global Posts
    6,226 Global Posts
    ROM
    NOS M7 Sense 5.0
    Default
    Thanks FD2
  5. #5
    Default
    very nice, i think i still prefer quick boot. its faster to hit that and reboot than holding the power button down or whatever.
    Curious, does quick reboot shut the phone down incorrectly though. I mean you select it then bam the phone reboots. While when you shut the phone off it goes thru the power down process thing. Anyone have an opinion either way?
    ~Matt
    Rooted Galaxy Nexus & Rooted Nexus 4
    Rooted Asus Transformer
    www.twitter.com/howarmat
  6. #6
    Qazme's Avatar
    Posts
    Global Posts
    2,956 Global Posts
    ROM
    Bugless Beast 4.1.1
    Default
    Quote Originally Posted by howarmat View Post
    Quickboot is exactly that, more of a reset switch than a full power down power on situation. Rather it matters or not I have no clue, but it couldn't hurt to shut it down properly here and there and do it the right way just in case.
    What's been your experience? Has the phone felt any different to you? (I believe the answer would be no since you still use it)
    NEXUS!!!!!!
  7. #7
    Default
    correct no difference in feel once it boot back up. I will still add the option from above since its nice to have them there too.
    ~Matt
  8. #8
    Default
    This is awesomee
    I can't hold a conversation without mentioning android
  9. #9
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    looks like i broke the ice lol
    I'm the ROOT man
  10. Thread Author  Thread Author    #10
    FD2
    FD2 is offline
    FD2's Avatar
    Shadow Lurker
    Posts
    Global Posts
    376 Global Posts
    ROM
    Stock
    Default
    Seems to be working correctly as most rom cookers are adding it to their roms now.
  11. #11
    Todd M's Avatar
    Posts
    Global Posts
    409 Global Posts
    Default
    Good find and good add. Just added it to my Virtuous 2.7 install!
  12. #12
    eRod v1.0's Avatar
    Posts
    Global Posts
    374 Global Posts
    ROM
    Jelly Bean!
    Default
    If you have a custom lockscreen loaded, like the rotary one you can get with Virtuous 2.7, this will not work with this mod. I loaded this up and and changed my lock screen to something else. Oh well. Extended Control widget lets me add a reboot button, so it's not a must have for now.
  13. #13
    Default
    i been lookin for something that did this...awesome post. thank you
  14. #14
    Default
    Quote Originally Posted by FD2 View Post
    Yep. ShadowRom has it built in.
    HTC Incredible
    Redemptive R-EVO-lution 1.9
    Hydra OCUV#3
    Clockworkmod 2.5.0.5
    Radio 2.15.00.09.01
    Unrevoked Forever
  15. #15
    Default Re: Add reboot and recovery to your power menu options.
    Hi, sorry but the zip file is not available, can someone tells me where i can find it?
    Thank's a lot
