Results 1 to 8 of 8
    Default Cyanogenmod-style menu bar power control for sense-based ROMs
    Alright, first of all, this is not my work at all. JsChiSurf on XDA did it all, but I was so excited to find it I had to share it with the people here. Anyway, I've been flashing and trying out a lot of ROMs lately, and one thing I really liked about the latest versions of Cyanogenmod was the power control widget in the window shade you pull down from the notifications bar (kind of a noob, sorry if I'm using the wrong names here). However, I really like Sense and wanted to stick with a ROM based on that. Now I found this and I don't need to compromise anymore!
    I have it running on Skyraider 3.3 fine, though it did take me a few tries for some reason so be sure to backup first.
  2. #2
    Default
    Aw, this looked really cool! I get a blank bar after I load it though. I wonder if this has to do with me loading the latest OTA patch.
  3. #3
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    Didn't work for me got stuck on splash screen
    I'm the ROOT man
    G Talk: Upstreammiami3o5
    Let me help you ROOT your phone
  4. #4
    Default
    Sweet looks so good thanks
    I can't hold a conversation without mentioning android
  5. #5
    dmoney17's Avatar
    Posts
    Global Posts
    91 Global Posts
    ROM
    Stock
    Default
    Didn't work for me either. I did try the customized power control buttons, so not sure if it was that one causing the problem.
    Sent from my DINC using Tapatalk
  6. #6
    jdkoreclipse's Avatar
    Banned
    Posts
    ROM
    My roms (link in sig)
    Default
    This should work for Evo based roms. My new (unreleased) rom has it cooked in
  7. #7
    dmoney17's Avatar
    Posts
    Global Posts
    91 Global Posts
    ROM
    Stock
    Default
    Does anyone know if there is a power control in notification bar that includes the auto-sync/background sync option? I'm running senseless revolution and the power control in the notification bar doesn't have the auto-sync as on of the options. I believe it has the mobile data on-off option.
  8. #8
    Default
    Is there a notification bar for aosp? Im using the gingerbread rom.
    I got a G1 the 2 days after it hit the stores, and 2 Android phones later it has gotten so much more Incredible
