1. hcole623's Avatar
    I just flashed to skyraider 3.3.4 and am very new to being rooted. I've heard great things about battery life improvement but i'm experiencing the furthest thing from it. In 3 hours my phone drained half the battery from a full charge NOT USING IT at all. Any suggestions? I have a stock radio/kernel/whatever its called, is that the problem?
    12-05-2010 02:24 PM
  2. bkorver's Avatar
    Sometimes you have to give a custom rom a day or two to settle down to it's new home. If you are still having problems tomorrow, try another rom or reinstall the current one...
    12-06-2010 11:34 AM
  3. I am138's Avatar
    Try running a Hydra under volt kernel, with set cpu.
    12-06-2010 09:52 PM
