ok so i tried to install a rom that i loaded onto my sd card using rom manager. i selected the rom and had it install. it loaded into clockworkmod recovery and started. it then stopped and said installation aborted
/tmp/recovery.log was copied to /sdcard/clockworkmod/recovery.log. please open ROM Manager to report the issue.
so at the top of the screen i have options like rebote system now
apply sdcard: update.zip
ect....
so i tried to select repote system now and the screen changes to a white triangle with a orange exclamation point in it with a little androind guy next to it and it does nothing then.
if i hit the power button it goes back to the previous menu.
i also tried to select backup and restore for the list of options. that also gave me the triangle.
so can someone please tell me what i need to do now so i dont bick my phone?
ect....
