Results 1 to 4 of 4
- 12-08-2010, 09:31 AM
Thread Author #1
- 12-08-2010, 10:17 AM #2
Try "Bluetooth Fix Repair" in market. May or may not work. Seems to have helped the same issue with me, but not totally.
- 12-08-2010, 10:30 AM
Thread Author #3
- 12-08-2010, 04:24 PM #4
Are you having a problem entering the PIN?
If that's the case you need to click the little OK at the bottom of the input screen and then the keyboard will enter the PIN.
I had the same problem until I hit the OK by mistake.Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
Reply
