Page 1 of 4 1234 LastLast
Results 1 to 25 of 78
    trock70's Avatar
    Posts
    Carrier
    Carbonite Fusion
    Default [ROM] Carbonite Fusion G v1.0 ***2.3.3 leak base*** (UPDATED 5/24/11)
    Updated with 2.3.3 leak base. I will still include the stable Froyo version for now until I believe the new one is stable enough to remove it. Enjoy!
    Indroducing Carbonite Fusion! This Rom is a beautiful creation In my opinion.
    This has been built to be aesthetically pleasing yet stable and fast Rom.
    Enhancements/Mods/Additions
    Carbonite Fusion G 1.0
    • Based off 2.3.3 leak
    • Most bloat removed
    • Gingerbread icons
    Carbonite Fusion v.5
    • Based on the latest Inc build 3.26.605.1
    • Now with Updater-script- Works on ClockworkMod 3 and up
    • This will always be themed in line with BrightSilence Carbon Espresso
    • Galaxy S battery
    • Notification bar widget
    • Reboot power menu (Normal-Bootloader-Recovery)
    • 6 bar signal
    • 5 column app drawer
    • Transparent app drawer
    • Gingerbread Keyboard
    • Added power control widgets settings app by JsChiSurf
    Removed from Rom- I will never include these as they slow things down- if you want them you are on your own
    • AmazonMp3
    • CityID
    • FMRadio
    • Stocks
    • HTC-Carpanel
    • Footprints
    • VCast
    • VZNav
    • MyVerizon
    • Skype
    • WiFiRouter
    I hope you enjoy this as much as I did making it for you!
    Major thanks to
    The testers- neur0tk1, TheBr0ken
    BrightSilence for the port [THEME] BrightSilence Black/Carbon Espresso v2.2a (Skin available for HD roms) - xda-developers
    IIIBoredIII and JsChiSurf for the Notification bar widget! [PORT][MOD][Deprecated] Notification Menu Power Control Widgets for Sense based ROMs - xda-developers
    snq- for the Reboot option in power menu [FX-MOD][SENSE] Reboot option in power menu 3-in-1 - xda-developers
    You can find some very cool Mods in this thread
    (Requests and Mods for Carbonite Fusion Rom) - xda-developers
    Anything you guys want baked in the Rom just PM me and I will look at it.
    IF YOU ARE UPGRADING FROM .5 THEN YOU MUST WIPE EVERYTHING.
    I TAKE NO RESPONSIBILITY FOR ANYTHING THAT MAY HAPPEN TO YOUR PHONE WHILE FLASHING ANY OF MY WORK
    See 2nd post for download link.
    You may find updates quicker by visiting OS Masterminds
  2. Thread Author  Thread Author    #2
    trock70's Avatar
    Posts
    Carrier
    Carbonite Fusion
    Default
    Ok here are some of the stock HTC apps. This is NOT a flashable zip file. Just unzip it to your SD card and install what you want through Astro.
    Multiupload.com - upload your files to multiple file hosting sites!
    Wallpapers
    This one was made by Stoney 666. Thanks Dude! Awesome work!
    Here are some HTC_IME Mods I made using gIMpSTa's Online theme Kitchen, I'm only posting these because he put a lot of work and effort into this and he needs much credit for it, consider a donation to him.
    Use these but definitely check this out
    Black and Blue
    Blue Blue
  4. #4
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Carrier
    CM-7
    Default
    I'll give this a shot over the weekend - looks really nice. Thanks!
  5. #5
    Default
    Looks pretty sweet, just flashed a ROM today so seeing how it is, this is next in line.
  6. #6
    jdkoreclipse's Avatar
    Banned
    Posts
    Carrier
    My roms (link in sig)
    Default
    One of my favorite ROMs!!!! Great work trock!
  7. #7
    Default
    This rom looks sweeeet!
  8. #8
    menschmaschine5's Avatar
    Posts
    Carrier
    Stock (for now)
    Default
    I'll definitely have to try that out when I get bored with my current ROM.
  9. #9
    Lee_Bo's Avatar
    Android Addict
    Posts
    Global Posts
    945 Global Posts
    Default
    I flashed this one today and it's running extremely smooth, absolutely zero lag. I think I'm going to hang on to this one for a while.
  10. #10
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Carrier
    KANG
    Default
    Looks great Trock I think i'll try it out! and btw great write up Stig!
    PvilleComp likes this.
  11. #11
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Carrier
    CM-7
    Default
    I like this one a lot - it really is Drama Free.
  12. Thread Author  Thread Author    #12
    trock70's Avatar
    Posts
    Carrier
    Carbonite Fusion
    Default
    Thanks for the great review P!
  13. #13
    Default
    one problem and maybe its just me, (great rom by the way) 3g hot spot settings force closes every time i try to open it. where i work the Internet it spotty at best so i use my phone to get Internet and cant use the 3g hot spot because it also seams not to work. other than that great work and love the rom.
  14. Thread Author  Thread Author    #14
    trock70's Avatar
    Posts
    Carrier
    Carbonite Fusion
    Default
    Did you try WiFi tether app?
  15. #15
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Carrier
    CM-7
    Default
    Quote Originally Posted by trock70 View Post
    Thank YOU for the great ROM!
  16. #16
    Lee_Bo's Avatar
    Android Addict
    Posts
    Global Posts
    945 Global Posts
    Default
    I flashed this ROM over the weekend, and of the three ROMs I have tried so far (Cyanogen, Warm Z, and Carbonite Fusion), this one has been the smoothest running so far. Absolutely no lag when scrolling between screens or multi tasking. I think I'm going to use this one for a while.
    Thanks trock70 for a great ROM and thanks PvilleComp for a great write up. You all kick butt!!!
  17. #17
    nygbrad's Avatar
    Posts
    Global Posts
    116 Global Posts
    Default
    I installed this last night and it worked great for about an hour. Then kept getting android force closed errors and it kept rebooting. Is there anything I can do to make this work? I like the Sense based ROMs. I tried wiping and reinstalling twice and the same thing happened each time. I also tried to upgrade and downgrade my Clockword mod too.
    I'd appreciate any suggestions so that I can use this ROM.
    Thanks!
  18. #18
    Lee_Bo's Avatar
    Android Addict
    Posts
    Global Posts
    945 Global Posts
    Default
    Quote Originally Posted by nygbrad View Post
    Thanks!
    When you booted into recovery, did you wipe data/factory reset and wipe cache partition? Also, go to advanved, and wipe dalvik?
  19. #19
    nygbrad's Avatar
    Posts
    Global Posts
    116 Global Posts
    Default
    Yes I did all 3 every time I reinstalled it. This is the only ROM I've had issues with. Figures, the one I'd probably like the most I have issues with haha.
  20. #20
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Carrier
    CM-7
    Default
    Try running fix permissions from recovery.
  21. #21
    nygbrad's Avatar
    Posts
    Global Posts
    116 Global Posts
    Default
    Well I reinstalled everything again and it works good. If it happens again I will try the fix permissions trick.
    Thanks!!
  22. #22
    nygbrad's Avatar
    Posts
    Global Posts
    116 Global Posts
    Default
    Did it again when I rebooted. Is there a lower version of Clockwork recovery mod I should be using? I was on 00.5 and it started acting up when I updated to 00.8.
  23. #23
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Carrier
    CM-7
    Default
    I used 0.8 when I loaded it with no problems. Did you run fix permissions in recovery yet?
  24. #24
    Default
    just found a wireless tether apk in this forum after a search. works perfect thanks again for a great rom!
  25. #25
    Lee_Bo's Avatar
    Android Addict
    Posts
    Global Posts
    945 Global Posts
    Default
    I'm still loving this ROM! I really like the screen animations. So smooth and lag free it's not even funny!
Tags for this Thread
