Results 1 to 6 of 6
    polito5778's Avatar
    Posts
    Global Posts
    19 Global Posts
    ROM
    UBER
    Default Need help ROM Manager error, can't fix
    Ok so I got my gf a D-Inc, the guy we got it from had it with Metro PCS, not big red. So it's rooted and loaded, but we want to flash the MUIU ROM and last night I hit a snag; or a hole, I have no idea.
    Root User Rights never asks when downloading anything, so I was already a little weary. ROM Manager then says error with user rights, but I was never prompted by my ninja. I tried everything and all I could find online was I need to unroot it, wipe it, then start over.
    Can anyone give me some advice? I have no idea where to start but I would love to get this thing to it's natural incredible'ness.
    Big ups to Ziggy471 for hooking up Uber ROM!
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    Did you try Fix Permissions in ROM Manager?
    If that does not work try loading from recovery without ROM manager.
    If that does not work you may need to reset, reload, re-root and rejoice.
    Hope this helps.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
    polito5778's Avatar
    Posts
    Global Posts
    19 Global Posts
    ROM
    UBER
    Default
    I think that may be the route I have to take. It won't even let me into recovery, I get a phone with an exclamation point symbol. I may just uninstall everything, un-root, start over. How do I un-root?
  4. #4
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    This thread ought to have everything you need!
    Good luck.
    polito5778's Avatar
    Posts
    Global Posts
    19 Global Posts
    ROM
    UBER
    Default
    ok I tried but because rom manager doesn't work, I can't flash clockwork recovery. still getting the icon of a phone with the exclamation point when I try and go into recovery manually.
  6. #6
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,101 Global Posts
    ROM
    JB
    Default
    Hit me up on gtalk I can help
    I'm the ROOT man
    G Talk: Upstreammiami3o5
    Let me help you ROOT your phone
