Results 1 to 3 of 3
    SilverLight98's Avatar
    Posts
    Global Posts
    574 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry Help - 5 vibrates and blinking green LED
    Hi, I'm having problems with my DINC.
    I was running SkyRaider Athena 1.2 with the stock Kernel, HBOOT 0.92, Radio 2.15.00.09.01 and S-OFF. It was getting a little slow and bogged down so I decided to start afresh and flash a new rom. I upgraded my Custom Recovery from 2.5 to 3.5 (it had been a while since I had flashed a rom) and flashed SkyRaider Sense 3.5.
    Here is where the problems start. Whenever I turn off the phone and try to turn it back on I get the "HTC Incredible" screen, which then goes to black and I get 5 vibrations and a green flashing LED. I can get to the bootloader but when I try to get to the Custom Recovery, the same thing happens. One thing that I have noticed is that S-Off is now S-ON.
    The only way that I can get the phone to turn on is to press the power button, and plug the phone into a usb for power. At that point it will start up normally, however the phone will not read the SDcard or internal phone storage at all, even in when I do the same thing to get to the custom recovery, which means that I can't flash roms, or use any apps that require some sort of memory.
    Any suggestions on how to get the phone working?
    Any help would be greatly appreciated.
  2. #2
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default
    There was another thread about this a little while ago...
    http://forum.androidcentral.com/htc-...tml#post602189
    Does anyone else have any additional insight?
  3. #3
    Upstreammiami's Avatar
    Posts
    Global Posts
    2,199 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    JB
    Default
    Tried helping the other Guy but no go. Told him ill probably fix it if he sends me the phone
Tags for this Thread
