Hello,
This is going to be a wall of text so I apologize in advance, just trying to provide some history to the problems I have had in case they are pertinent to resolving my problem.
I am currently using my DINC that I got the day they launched - had some minor issues at first (but who didnt?) and decided a few months back to root. No issues in the process I was running Virtuous and after a while started getting random restarts. After a couple weeks of tinkering I decided I just might have an issue with the phone and wanted to take it back to stock, just to see and maybe even try for a replacement.
After a long (2 day or so) FUBAR process I finally got my phone back to stock and working correctly (or so I thought). Apparently the stock rom I was trying to flash was pre 2.2 and the update would never load. I eventually found a stock rom that had 2.2, flashed it, ran s-on tool and the phone stabilized and all was good. Until another update was pushed some weeks (maybe months) back that I still cannot load. I decided to ignore it, but now my phone has gotten so awfully slow and battery inefficient that I am fed up.
Decided to re-root and try cyanogen 7, rooted fine, loaded cm7 not so fine. RC2 never loaded, just sat at the load screen, RC1 loaded, but nothing, NOTHING would run, everything force closed. 6.1 worked, but couldnt get contact list working and so I backed up and am back to my stock setup, horrible performance and battery life included. I hadnt performed a factory reset (my bad for not reading enough) so I tried that and upon boot up for the first time...my background was the same, launcherpro was still active and all shortcuts to my apps were on the screen, although they lead to nothing...wtf?!
What has happened? It wont even do a factory recovery now?? Any help would be greatly, greatly appreciated...
