Results 1 to 4 of 4
    lspot7899's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Force Close on Settings / Sound
    I just finished setting up CM7RC2 and got all the G-Apps install and also my other app. Was working fine one day and then the next everything wanted to force close. Ran ROM Manager and Fix Permissions and that seems to help, but when I got to Settings / Sound it keeps giving me a FORCE CLOSE. Any help would be great.. This is the only problem I have at the moment with CM7 RC2. If none may need to flash again and wipe. Hate to do that. Help please
  2. #2
    crondable's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP
    Default
    Just flash the newest nightly. Much more stable then RC2.
    lspot7899's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by crondable View Post
    Is that Gingerbread? and how stable is it? I don't want to keep installing apps over and over every time I flash...
  4. #4
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default
    It's very stable. #28 is the most current. The link for download is in the OP of the CM7 nightly thread.
    You do not have to do a full wipe whne installing the nightly over RC2, just cache and dalvlik. All your apps and settings will remain.
