Results 1 to 6 of 6
    IanAck123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 6.1/Invisiblek #18
    Default Unrooting help.
    Alright guys i just tried searching this forum for unrooting methods and i couldn't find any instructional threads.
    I am on CM7 RC4, CWM 3.0.0.8, 2.15.00.11.19 radio and S is off. I also have a custom splash screen for the "HTC Incredible" for the initial boot. Can someone PLEASE explain to me how I can revert this phone back to fully stock? I am trading it today around 1PM for a Tbolt. Thanks guys, I appreciate it.
  2. Thread Author  Thread Author    #2
    IanAck123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    wait, i just found a tutorial. do i really have to be on a windows computer? i am on a mac...
  3. #3
    PvilleComp's Avatar
    Posts
    Global Posts
    4,265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM-7
    Default
    If you are using the instructions in this thread
    http://forum.androidcentral.com/htc-...ncredible.html
    Then you will see 2 methods for unroot.
    First you need to turn S-ON for either method.
    The RUU exe install requires a PC. There is no Mac version.
    The PB31IMG.zip method does not require a PC, just download it to your phone, make sure the file is named PB31IMG.zip and flash it in HBOOT.
    Your SD Card MUST be FAT-32 format for this to work.
    Hope this helps.
  4. #4
    Lee_Bo's Avatar
    Android Addict
    Posts
    Global Posts
    967 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by PvilleComp View Post
    Hope this helps.
    I've done two this week for friends who were trading in their Inc's for TBolts and it works great. I personally am keeping my Inc with Cyanogen 7 and 11.19 radio.
  5. #5
    Lee_Bo's Avatar
    Android Addict
    Posts
    Global Posts
    967 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by IanAck123 View Post
    You will have to flash your radio (2.15.00.11.19) back to stock first.
    IanAck123's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    i got it, thanks guys. the guy ended up flaking last minute -__-. i unrooted for no reason. oh well, CM7 stable is coming out in a few days so i guess ill wait for that so i can have a freshly rooted phone.
