Results 1 to 10 of 10
    Default Need Help.
    I was using warm z twopointtwo and I decided to try skyraider 4. I backed up the warmz rom and installed skyradier 4. Well I decide to go back to warm z but my backup will not restore. I get stuck on the white htc droid incrdible screen. Any ideas?
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    Were there any error messages when you did the restore? Warm Z can be tricky. Try clearing data, cache and dalvik twice each before running your nandroid again. Also chack for any error messages during the nandroid restore.
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
    Default
    Ok i will clear both a few times and then look for an error. I am also using Clockworkmod 3.0.08.
    Default
    also when i restore there is no error message. it doesnt to take as long as a full back should take
  5. #5
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    Do you have an earlier nandroid you can restore?
    Default
    yes but this is my wifes phone and she wants the warm z nandroid. I wonder if rom manager did not fully backup the nandroid?
  7. #7
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    Are you restoring the nandroid in ROM manager or in Recovery? If you are restoring in ROM manager, try doing it in recovery.
  8. Thread Author  Thread Author    #8
    Default
    I backup in rom manager but trying to restore in recovery
  9. #9
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    If it's running really fast and not giving any errors, you likely have a bad nandroid. Either re-flash warm Z or restore to an earlier nandroid.
    Sorry.
  10. Thread Author  Thread Author    #10
    Default
    ok thanks
