I orginally posted this on the xda developer's forum thinking someone there could help but I didn't get any responses so hopefully someone here has some suggestions.
I apologize for the long post but I wanted to provide as much info as I could about my issue.
I need some help from the experts?.
I have an incredible and here is the current state of the phone:
rooted
s-off
Amoled
ROM SkyRaider 2.5.2 Sense
Radio 2.15.00.09.01
Chad?s Incredikernel 2.6.32.26
Clockwork 3.0.0.8
I have been running SkyRaider 2.5.2 Sense for quite sometime (as you can tell by the version number since he is now at v4.0) and like the ROM it runs great and has been very stable. About 6 weeks ago (Mid March) I decided to try IncRom and installed 1.5 Beta2, it was a great ROM and I liked it so much when IncROM 1.6 came out I installed that about 4 weeks later. As an FYI I did a full wipe of data and cache between all ROM changes. I like that ROM as well but here is where it gets a little strange. About a week ago (or so) my friendstream stopped updating my FB updates and would only update my twitter and my contacts in my phonebook that I have linked to FB their pictures and status that scrolls under their name on their contact record stopped updating and was stuck with the status messages and profile pics from a week ago (when the last update took place). Now when I go to settings, account & sync and view Facebook for HTC Sense it is selected for updates ever 2 hours and contact records and live feeds are both selected as well. I can even have it sync now and the data sync circle comes up showing syncing but nothing changes when I go check statuses and profile pics. I also have the FB app that I use to and it runs perfectly, I even tried to ?add account? in account & sync and add the actual FB app instead of FB for HTC Sense but when I try to selected FB nothing happens. So after fiddling with this for a while (clearing cache, data and stuff for FB and FB for Sense in settings>applications>manage applications menu and it nothing changed I decided something was hanging up somewhere so I decided try a new ROM and see if it had something to do with IncROM 1.6 so I went to SkyRaider to install 4.0. I did a complete data and cache wipe by doing a factory reset in Recovery and then I installed the ROM. I did this via recovery and not ROM Manager. The ROM installed with no issues that I could tell and when I went through the initial set up process where you are entering your Google account, wifi info, location tracking stuff, all went well until it came to the part where you were asked to provide your FB, flickr and twitter info. I selected FB and entered my login credentials and when I selected OK there was a pause and then an error box appeared with a message saying process unavailable at this time do you want to try again or cancel (I don?t have the exact wording of the message but you get the idea). I selected try again several times but the exact same message kept appearing so I ha d no choice but to select cancel. I decided to go on with the set up process and try my Twitter logon and I put in my credentials and waited and waited while there was a line going in a circle like it was trying to do something. I never received an error message as I eventually hit the back arrow and it canceled out of trying to log me in to twitter. I did that a few times and decided to jus skip the FB/Twitter log on process during set up. Once set up was complete everything about the ROM look and appeared to function perfectly except anything having to do with FB or Twitter regarding Sense (no FB pics for my contact records, no status updates because I was unable to log into FB to pull and sync those contact records). So I decided to just do a Nandroid restore from a time where I knew FB for Sense was working. So I went back to my 3/18/2011 nandroid restore which was when I went from Skyraider 2.5.2 to IncROM 1.5 beta2. When I did the nandriod restore everything came back as expected but my friendstream and all my FB for sense would not update with the current updates, it was stuck on the last update as of 3/18/2011. So I went back in to recovery and did a full factory reset and data cache wipe and did another Nandroid restore to another restore point and the same thing happened all restored without issue but anything having to do with FB for sense (contact pics and status updates) were stuck from the last update that was done prior to the nandroid backup and would not update the to anything current.
So I said all of this to say, when you do a full wipe of data and cache via ROM Manager or a factory reset via recovery what does not get wiped? Something is not wiping out and Sense stuff specifically FB and Twitter is not working like it should and what do I need to do to fix my FB and Twitter Sense stuff. Is this and issue of Clockwork 3.0.0.8? Any help would be greatly appreciated!!
rooted
s-off
Amoled
Radio 2.15.00.09.01
Clockwork 3.0.0.8
