Results 1 to 3 of 3
    Jerry Hildenbrand's Avatar
    AC Cowboy
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    Homebrewed
    Default Raw Gingerbread leak mirrors
    Wanted to give you guys a way to get the untainted GB leak without Google translation or learning Chinese or dealing with spotty mainland Asian servers
    And mirrors are always a good thing, right?
    Thanked by:
  2. #2
    PvilleComp's Avatar
    Posts
    ROM
    CM-7
    Default
    Thank you sir!
    Some say that his dormant chips were left that way for YOUR SAFETY... Others say that once "turned on," he can not be turned off... All we know is... He's called The Stig.
  3. #3
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,055 Global Posts
    ROM
    Jelly Belly
    Default
    ...Impatiently waiting for screenshots and videos. I really like the features in Skyraider 4, so I probably will stay with that long term, but I am interested in checking out this GB sense build.
    Please use the Thanks button below and to the right.
