DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Page 1 of 2 12 LastLast
Results 1 to 25 of 42
    Default Infuse HELP!!!!!
    The infuse was downloading n just went black no lights logo or screen help
    Sent from my LG-P505 using Android Central Forums
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Default Re: Infuse HELP!!!!!
    downloading what?
    Default
    Useing Odin 3 to return it to factory
  4. #4
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    did the cable come out? did you notice where it died?
  5. #5
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    can you get it into Download mode?
    Default
    It said Odin failed n he pulled the cord out
  7. #7
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    can you get back to download mode?
  8. Thread Author  Thread Author    #8
    Default
    No the phone doesn't come on at all no lights nothing and the computer doesn't recognize the phone being plug in
    Default
    Is it screwed?
  10. #10
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    pull the battery, pull the sim, pull the sd card. let it sit for 10 minutes or so and try again with just the battery in.
    I know it seems odd, but that you to help it do a reset....you did get all the way to the point of where it said that odin failed right? you didnt pull the cord while it was still doing its thing...
    I will keep checking this thread so take your time
  11. Thread Author  Thread Author    #11
    Default
    Yeah it was all the way finished n had been for a lil bit, thank you sooo much ill let u know
  12. #12
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    you are doing this to get to download mode: Make sure odin is open first, then remove battery, put back in, hold both volume keys in, and plug in usb cord.
    just checking....
  13. Thread Author  Thread Author    #13
    Default
    Okay we took everything out n just put the battery in it didn't work, is it possible to fry the battery... n should everything be back in it before we do the above
  14. #14
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    the battery should have been out while using odin. I never heard of a battery frying from it. no, do not bother putting it back in, just follow the instructions in my last post and try for download mode again.
    If odin just failed and was totally done, you should have either soft bricked it, boot looped it or did absolutely nothing to it. any one of the three are easy to solve. I am kinda stumped as to why it will not turn on at all...trying to do some research on it now
  15. Thread Author  Thread Author    #15
    Default
    Yay!!!! Its in download mode says its downloading Odin isn't running.... now what? He already uninstalled the Samsung drivers idk how it even recognized it please continue to help me, bc idk
  16. #16
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    YEAHHHHHH!
    ok hold tight for a second....you are in good shape. Getting into DL mode is what was needed....BRB
  17. #17
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    is the computer and odin recognizing the device?
  18. Thread Author  Thread Author    #18
    Default
    No it doesn't show on either
  19. #19
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    do you have the battery in or is it connected to the usb with the battery out?
  20. Thread Author  Thread Author    #20
    Default
    Battery in and its in downloading mode
  21. #21
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    ok odin will always fail (well 99% of the time) if you have the battery in. before I give you detailed instructions on what to do, I need to know what you were trying to do.
    Were you installing new ROM? Rooting? let me know and I will give you the step by step on how to fix it
  22. Thread Author  Thread Author    #22
    Default
    Trying to root it and get the bloat ware off but at the time he was just trying to do a factory reset like restoring it from the gingerbread 2.3. whatever update
  23. #23
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    ok so lets go with a rooted stock ROM. I take no real credit, the credit is jscott30 over on xda. I am just relaying it to you and making it easier.
    first download this:
    now the instructions:
    1.) Download and extract the zip package.
    2.) Place phone in download mode. Make sure odin is open first, then remove battery, put back in, hold both volume keys in, and plug in usb cord.
    3.) If needed, install latest Samsung USB drivers by installing Samsung Kies from HERE. you said you have them. if not install them from
    4.) Open the included Odin exe.
    5.) If phone is detected, the window under ID:COM will turn yellow.
    6.) Click on "PIT" to browse to and select infuse_gb.pit. Make sure that Re-Partition is selected.
    7.) Click on "PDA" to browse to and select PDA_UCLB3.tar.md5.
    8.) Click on "PHONE" to browse to and select PHONE_UCLB3.tar.md5.
    9.) Click on "Start", and allow Odin to flash the phone. Do not unplug or power off the phone until Odin is finished.
    10.) When the Odin dialogue reads "PASS!", the phone should reboot into the stock UCLB3 Setup Wizard.
  24. #24
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    follow those exactly
  25. Thread Author  Thread Author    #25
    Default
    K ill let u know
