Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By sledge007
    gollum18's Avatar
    Posts
    ROM
    G3k 1.1/Kettle Corn 1.1.1
    Default Ingress map issue
    Hi guys I've been trying to play ingress for two weeks since I got the invite, but every time I go to collect exotic matter or anything it doesn't show me moving on the map. I play at my college for obvious reasons since I'm moving constantly but the game doesn't recognize that I am.
    I also have another issue where when I zoom out or in, any exotic matter that was on my map disappears and doesn't reappear so I can collect it.
    Is anyone else having these issues, if so have you found any ways to fix them?
    Sent from my SPH-L710
  2. #2
    sledge007's Avatar
    Posts
    Global Posts
    6,740 Global Posts
    ROM
    Wicked Sensations
    Default Re: Ingress map issue
    Open up your OPS screen and scroll to the right to DEVICE. Third section down DATA, then FORCE SYNC. Sometimes turning off/on GPS and/or WiFi helps with this issue. Note that in area with tall buildings, your GPS signal will bounce like crazy.....just like a Garmin or TomTom.
    Due to the cancellation of the penny, I no longer give 2¢ about anything. I may however, give a nickel
    bevcraw likes this.
    gollum18's Avatar
    Posts
    ROM
    Thanks for the fast reply
  4. #4
    vNaK's Avatar
    Posts
    Global Posts
    141 Global Posts
    I found that sometimes with mobile data off it doesn't detect GPS for some reason.
    You can test out your gps with GPS Test or GPS Fix and see if it your GPS works too.
  5. #5
    sledge007's Avatar
    Posts
    Global Posts
    6,740 Global Posts
    ROM
    Wicked Sensations
    You can't play the game if your data is off.
  6. #6
    vNaK's Avatar
    Posts
    Global Posts
    141 Global Posts
    I have mobile data off but connected to my mifi hotspot.
  1. "Home" soft key mapping issues
    By JOrtenzi in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 03-30-2011, 02:29 PM
  2. Google Maps Issue
    By Pops57 in forum Verizon Droid Incredible
    Last Post: 03-10-2011, 12:10 AM
  3. Google Maps Issues w/OTA 2.2 ?
    By DroidRage79 in forum Motorola Droid X
    Last Post: 09-22-2010, 01:07 PM
  4. Google Sky Maps issue
    By Atlienzz in forum Android Applications
    Last Post: 09-22-2010, 09:59 AM
  5. Google maps issue
    By iamgov#ac in forum Motorola Droid X
    Last Post: 07-18-2010, 02:50 PM
