Which radio is the best for Inspire on CM7...not nightly's??
fubaracing7374
135
I've looked over all the forums and can't find a straight up answer. I rooted my Inspire using the Ace Hackkit and loaded CM7 onto it. I didn't do anything to the radio and it just seems that my radio goes in and out of signal often. I'm wondering if I have a screwed up one. I have the CM7.1.0-RC1 with baseband 12.56.60.25U_26.10.04.03_M. Is this the most current one?
Not sure about the RC but this radio is the same one that I use on CM7 nightlies #219 and I had no issues at all. Sorry that I can't tell you which is the best for your ROM but if you like CM7 then I would recommend you try the nightly # 218 or #219. Both are very stable and I never had any problem, good battery life too.
A radio that works good for one person might not for another. If you think your radio is the issue best to try flashing another one then give it 24 to 48 hours to "settle in". Just make sure to also flash the proper RIL for your radio and rom.
There's Tons of info on radio's/RIL's over in the radio thread at XDA.
Estherlampard
